Use lighter menu hamburger icon on site without custom header?
  • catherinetoews
    I’m working on a build using the Supernova starter site. I like everything about the header/primary navigation except the menu toggle which is a bit too heavyweight for the typography on the site. On other sites where I’ve used the custom GB site header element, I know there’s the option to switch to the lighter weight toggle icon. Is there any way to do this quickly and easy on a site such as Supernova where the custom site header element isn’t active?
    Thank you!
    Catherine
  • Hi Catherine,
    Can you try the last PHP snippet in this doc and replace the SVG code with your own SVG code?
    https://docs.generatepress.com/article/generate_svg_icon/
    Let me know if this helps!
  • Thanks so much, Ying! Works well. 🙂
  • Glad to hear that 🙂
