Simply using GB Dynamic Data like I’ve done many times. Author meta > user_url doesn’t seem to work at all.
I read Ying’s explanation for why that might not work in another thread. However I see several other posts from Ying or others where they recommend the exact configuration I’m using (like here, here, or here).
I also see
user_urlavailable as a field fromauthor_metaon WordPress codex. So as far as I understand, it should work, but it doesn’t. I’m confused as to Ying’s explanation for why it should not work though, and I wonder if there is something I’m missing here.Context: I’m working with a Content Template element here.
Thank you for your help
Use GP’s dynamic data option in the top toolbar (green arrow):
https://app.screencast.com/7Tt0JDQD4NhRI -
Strange, I’m positive I had tried that… but I tried again and made sure to remove all configuration from the GB Dynamic Data pane (sidebar), and this time it worked. Thanks Ying!
Glad to hear that 🙂
