Using a site from the site library
    i built another site with GeneratePress and this time i used the Site Library for a head start. I imported everything since the installation was blank. After creating all the content and images and pushing the site to Live i figured out that some of the original pages where ranking on Google with the subdomain.
    My question is: the pages and posts i dont need on my website i simply delete, right? There are still some Elements installed where i am not sure of if they are in use on the website i built. How can i figure that out? Otherwise i just would delete them or you would not recommend that?
    Thank you for your help!
    Yes, correct.
    You can try setting the element’s status to draft to test, if the site looks/functions the same, then you can remove it, otherwise, you need to keep it.
  • Hi Ying,
    okay thank you. That’s simple – didn’t come to my mind.
    And the page with is still ranking on Google now, what is the best doing with it? Just deleting it too?
    theres a few choices.
    You can use a redirect plugin and set up a 301 redirect that URL to another page.
    Or you can use a SEO plugin to return a 410 status code for those URLs to tell Google the page has permanently gone.
  • Okay, that’s very helpful. Thank you, David! I know it’s not GeneratePress related but i really appreciate the help a lot!
  • Glad to be of help!
