Using Info Theme and Having Issues with Grid.
  • Hi, having issues with grids on the home page using info theme. There’s the right sidebar, and the categories below the right sidebar expand to the very right. How do I keep the bottom category grid the same width as the top category grid?
  • On Chrome it looks fine, but it’s having issues with Firefox and Microsoft Edge.
  • Just checked incognito for Chrome, and it’s having issues there too.
  • Hi John,
    It’s a caching issue. To test this out, add a /?nocache at the end of your URL.
    With that said, try disabling any caching/optimization plugins you have to test which one is causing this.
    Once you’ve figured out the cause. Try clearing its caching or checking which optimization feature is causing the issue.
  • Wow, that cleared it up. Turns out it was the WP Fastest Cache plugin. I clicked on the following button and it worked: Delete Cache and all minified JS/CSS files.
  • I see. Glad you found the cause!
  • Thanks for your help!!!!
  • You’re welcome, John!
