one more question… Can you tell me how to make a vertical accordion with Generateblocks1.8?🙏
I’m not sure what you mean by vertical accordion, can I see an example?
I mean with the tabs side by side and not one below the other.
That isn’t possible with the Accordion block. If you need that kind of layout, the best option would be to use the Tabs block instead.
Of course ! 🤦♀️
Thanks Alvind -
No problem!
