Vertical align item inside a container
    I have doubt with containers and flex, I want to achieve this:
    Service block
    But I can’t align the “Lorem ipsum” text block to the bottom right.
    Another question, is how to align items in slide out menu.
    Slideout design
    can you raise a separate topic for the Off Canvas panel.
    1. Start with a parent Container Block
    Layout > Display: Flex, Flex Direction: Row, Flex Wrap: Wrap.
    2. inside parent container add a Container Block for your heading and meta.
    Sizing > Width -> 100%
    3. inside parent container add another Container Block for your text
    Sizing > Width -> 50% or use Max-width for a pixel value.
    Spacing > Margin > Left to auto – this will push it over to the right.
    Or you can set the Parent Containers Layout > Justify content to Left.
