Vertical align
  • Hi, I’m new on GP. I’m trying to customize local pattern. I’ve also tried from scrtach.
    On this page, I’m unable to vertical align the text “H1 Medium length hero headline” in the block.
    https://antibesvet.fr/1092-2/
    Could you help ?
    Thank You
  • Hi. Could you check this please ? Thank you
    the simplest fix would be to remove what you have built so far, and add the Hero 3 pattern from the GB Pattern Library.
    As that has the centered layout you require.
    If you then have any difficulty modifying that pattern let us know.
    And just to manage expectations, we aim to reply to all support topics within 24hrs Mon-Fri, Weekends can take longer. But our average response time is within 6hrs during the week.
  • OK Thank you very very much. I’ll do so. But stil. I really don’t understand why I cannot align this texte vertically.
    I’ve tried to align everycontent vertically but it stills aligned on top.
  • You have made several changes to the original template which will make it tricky for me to explain what is required.
    If you use the original template. update your text and background image, then let us know.
    We can then assist with other changes.
