Vertical Alignment in Flex Container
  • unevenlane2025
    I am having trouble with the vertical alignment on flex containers. For the icon boxes as the top of the page, I am trying to get the icon and the header to vertically align, but I’m stuck! No matter how I configure the alignment there is always a bit too much space on the bottom of the headers. There is not margin/padding applied – everything is set to flex. Everything is set for vertical center alignment.
    https://timelyschoostg.wpenginepowered.com/?page_id=403
    The h3 heading seems to have a default bottom margin of 20px (set in the Customizer). Just override this value in the GenerateBlocks settings (set margin-bottom to 0).
  • unevenlane2025
    Thank you! That worked.
  • No problem!
