Anonymous
We have a left vertical main menu with one sub-menu (under the “Art tab”). Clicking on the “Art” tab correctly expands the sub-menu, however when any of the sub-pages are clicked on, the sub-menu collapses.
For both Desktop and Mobile, we would like the sub-menu to remain expanded when any of the sub-pages from that sub-menu are currently active. Similar to how the “Works” menu tab and expanded sub-menu works on the NK site (provided in the Private Info box).
The mobile menu currently uses the Off-Canvas Panel. The styling still needs work, but the basic functionality is there.
Is there a small code snippet we can add that would automatically apply the “toggled-on” class to <ul class=”submenu”> whenever one of the sub-pages is being viewed/active?
The site is currently hidden behind a Coming Soon page, so you will need to login to viiew. Credentials and the Site URL are provided in the Private Information box.
Thank you.
That will require custom JavaScript. Here’s what I can came up with:
document.addEventListener('DOMContentLoaded', function() { // Check localStorage on page load and apply toggled state if needed const currentSubmenuId = localStorage.getItem('currentSubmenuId'); const currentPath = window.location.pathname; // Get all the links in the current submenu const currentSubmenu = document.getElementById(currentSubmenuId); if (currentSubmenu) { const submenuLinks = currentSubmenu.querySelectorAll('a'); const isCurrentPathInSubmenu = Array.from(submenuLinks).some(link => link.getAttribute('href').includes(currentPath) ); // Only keep submenu open if we're on one of its pages if (isCurrentPathInSubmenu) { currentSubmenu.classList.add('toggled-on'); } else { localStorage.removeItem('currentSubmenuId'); } } // Set up click handlers for all menu items const allMenuItems = document.querySelectorAll('.menu-item a'); allMenuItems.forEach(item => { item.addEventListener('click', function(e) { const clickedSubmenu = this.closest('.sub-menu'); // If this is a submenu item if (clickedSubmenu) { // Store this submenu's ID localStorage.setItem('currentSubmenuId', clickedSubmenu.id); // Ensure it stays open clickedSubmenu.classList.add('toggled-on'); // Remove toggled-on from all other submenus document.querySelectorAll('.sub-menu').forEach(menu => { if (menu.id !== clickedSubmenu.id) { menu.classList.remove('toggled-on'); } }); } else { // If clicking a main menu item, clear all submenus localStorage.removeItem('currentSubmenuId'); document.querySelectorAll('.sub-menu').forEach(menu => { menu.classList.remove('toggled-on'); }); } }); }); // Use MutationObserver to prevent unwanted closing const observer = new MutationObserver(function(mutations) { mutations.forEach(function(mutation) { if (mutation.type === 'attributes' && mutation.attributeName === 'class') { const submenu = mutation.target; const currentSubmenuId = localStorage.getItem('currentSubmenuId'); if (currentSubmenuId === submenu.id) { const submenuLinks = submenu.querySelectorAll('a'); const isCurrentPathInSubmenu = Array.from(submenuLinks).some(link => link.getAttribute('href').includes(window.location.pathname) ); if (isCurrentPathInSubmenu && !submenu.classList.contains('toggled-on')) { submenu.classList.add('toggled-on'); } } } }); }); // Observe all submenus document.querySelectorAll('.sub-menu').forEach(submenu => { observer.observe(submenu, { attributes: true }); }); });
If this doesn’t work, you may need to reach out to a custom developer for assistance, as this is outside our support scope.
Anonymous
Thank you so much. This worked perfectly on Desktop!
For the mobile menu, since the hamburger menu closes and is regenerated every time a menu tab is clicked… is there some CSS or code that can easily keep the mobile sub-menus always expanded/open? So, once a visitor clicks the hamburger menu icon, they see the full, expanded mobile menu?
Would be better if visitors don’t have to click multiple times to view the sub-menu pages, plus since the mobile menu is hidden by default. I searched the web and the new support forum and tried a couple of the CSS-based solutions, but they didn’t seem to work properly.
Try this CSS:
#generate-slideout-menu.main-navigation ul ul { display: block !important; opacity: 1 !important; visibility: visible; height: auto; }
Anonymous
Fantastic. Works great. Appreciate the super fast reply!
Glad to hear you got it working!
