eastwood501
I see that shapes can be added to the bottom or top of horizontal containers, but how can i achieve this angled or wavy vertical shape as per the two links below with Generatepress.
https://www.weddingwire.com/wedding-ideas/about-us
https://www.weddingwire.com/wedding-checklists.html
https://www.racv.com.au/home.htmlRhanks
That type of effect is not using the ‘Shape’ feature but rather just custom CSS. Let us know if you need assistance with that.
eastwood501
yes could you suggest some CSS that i could use to obtain these effects, it would be hugely appreciated.
Sure, could you link us to the section on your site where you want to implement this effect?
eastwood501
Please see the website hero sections in link provided (private info link).
Are you able to show the straight angled divider like the ‘weddingwire’ site, and then also provide a solution to do the ‘wavy’ vertical divider like the RACV website linked on my original support ticket.
its possible in GenerateBlocks 2.0.
Which is coming close to the end of Beta testing.
Is that something you can wait for ? Or you can test today ?let me know.
eastwood501
Hi David. I am happy to wait for 2.0. What is the ETA release for 2.0? I tried to use it but had to revert back to 1.7
By the way where would I find this vertical shape divider setting be found in 2.0 when it comes out?
We’re aiming for a release in 14th January:
https://generatepress.com/generateblocks-2-0-a-new-era/
For adding shapes in GB 2.0 – see here for reference:
https://app.screencast.com/FiV9rzzv4DuMd
Summary:
After adding your custom SVG you can set its Position of Top , Bottom and Left to0– removing the Right value to position it to the left side.For reference the custom svg I used was taken from the examples site:
<svg aria-hidden="true" preserveAspectRatio="none" xmlns="http://www.w3.org/2000/svg" viewBox="0 0 32 400" fill="none"><path d="M23.014 144.538C16.7867 187.115 1.88699e-06 230.252 0 400L4.44656e-06 -3.05176e-05H30.3243C34.9271 47.0588 29.2413 101.961 23.014 144.538Z" fill="#0067F6"></path></svg> -
eastwood501
Awesome. Thanks David looking forward to the release and trying this!
You’re welcome!
