Vertically Align Images
  • How do I vertically align all the logo images that appear on this page? The first is displayed via custom code the others are embedded images.
    Do you want the image to align with the top of the text?
    If so, you need to crop your images to the edge of the actual logo; they are currently square and taller than the text section on the right.
  • Hi Ying, I’m trying to get the images to appear vertically centrally along the text to the right.
    First, select the container that wraps the text column and set its Display to Flex.
    Then, inside that column, select the container that holds all the text and set its Top and Bottom Margins to auto. That will vertically center the content.
  • Great, thanks Alvind.
  • You’re welcome!
