Maznet
How do I vertically centre align content within a Container?
Select the container, set
displaytoflex,align-itemstocenter. -
Maznet
Is there a way to do this without using display: flex, as this throws out the layout completely?
I remember there was a way to set the margin or padding to something that would achieve the same thing but I can’t remember what it was.
Which container on the site are you referring to?
Maznet
It’s the column with H2 title called ‘THIS BLOCK’
See screenshot here – https://ibb.co/Q3JyY8dG
Is it only the heading you want to center? If so, select the column container and set the text alignment to center under the typography settings.
Maznet
No, it’s all the content, including the YouTube videos.
select the container with class
gb-element-26c00d91, and setalign-items tocenter. -
Maznet
Perfect, thanks Ying.
No Problem 🙂
