Matias
Hi team,
My view is not the same when I go to my website, as shown in my customize section. I purged the cache but still having the same issue.
Also, probably is due to the same issue as above. I set an image as background on a container for my home page and it’s not displaying.
Please try #1 here to eliminate conflicts from elsewhere first:
https://docs.generatepress.com/article/debugging-tips/If that doesn’t help then take a look at this article:
https://docs.generateblocks.com/article/unstyled-content/Let me know 🙂
Matias
Hi Leo,
Thanks for the fast response!
Indeed, there was an issue with a Plugin, bunny.net. What should be my next steps to get this fix and continue to use this plugin?
Hi Matias,
Glad you’ve found the cause.
I assume this is a cache plugin. Next, you can reach out to the plugin support for how to avoid this issue 🙂
The Unstyled Content linked above provides some insight as well.
