Want this layout for menu navi + logo
  • hi
    how are you
    the current is https://tinyurl.com/23l8amsg
    but the final look I want is https://prnt.sc/4MIkulfd0akX
    1. move search box to the right
    2. how to move logo to left before the whole navi menu? i have tried many times to adjust them and I failed, thanks
  • To move the logo to the left, go to Customize > Layout > Header and set the Header Presets to Default.
    To fix the search box issue, I need to check your Customizer CSS section, but the credentials you provided in your other topic are incorrect, so I cannot log in to inspect.
  • hi
    done as u told me https://tinyurl.com/26v3gno5, but it is not good, please check the website menu
    i will check it and send you soon
    in Customizer > Additional CSS , remove the following CSS:
     /* Site title*/
    .site-branding-container {
    	flex-direction: column;
    .site-branding-container .site-logo {
    	margin-bottom: 0.7em;
     /* Menu bar */
    .main-navigation .inside-navigation {
    	justify-content: space-between;
    .inside-navigation .main-nav {
        margin-left: auto;
        margin-right: auto;
        left: 0;
        right: 0;
        text-align: center;
    @media (min-width: 921px) {
    		position: absolute;
    		margin-left: 5%;
    		margin-right: 5%;
    Then in the Customiser > Layout > Header check the Navigation as Header option.
    Once thats done let me know, and I can advise on spacing of the nav menu and items
  • HI David
    All are done with your steps,
    I have to say that every journey is perfect under your guide.
    Yes, as you said, give me your advice on spacing of the nav menu and items
    I think this one is better for nav menu space like this https://tinyurl.com/29bfndhk
    Looking forward to your reply , David
  • Hi david,
    Still need to add the background color to two menu items of ” resources” and ” get a quote” like this example https://tinyurl.com/2c2qt5u4?
  • Ok.
    1. adjust the spacing add this CSS:
    #site-navigation .inside-navigation {
        justify-content: center;
    #site-navigation .navigation-branding {
        margin-right: 10px;
    2. to set the background colors of the last 2 menu items:
    /* style one from last menu item */
    #site-navigation .main-nav > ul > li:nth-last-child(2) a {
        background-color: #f00;
        color: #fff;
    #site-navigation .main-nav > ul > li:nth-last-child(2):hover a {
        background-color: #00f;
    /* style last menu item */
    #site-navigation .main-nav > ul > li:last-child a {
        background-color: #0f0;
        color: #fff;
    #site-navigation .main-nav > ul > li:last-child:hover a {
        background-color: #0ff;
