digital now
Hi generatepress team,
I´m looking for a simple popup solution, I was working with “simple modal” (recommendation from Mike Oliver – which I think is from one of you) but I´m not sure if it’s getting updated. So I searched and found a recommendation from Jonathan Jernigan (https://jonathanjernigan.com/easy-popup-modal-in-generateblocks-pro/).
What would you recommend?
best wishes
We don’t have a specific recommendation for that, but both suggestions seem fine, and it all depends on which method you prefer. Jonathan’s method involves custom code; if you’re comfortable with that, then you can go ahead with it. Otherwise, you can use the plugin method. 🙂
digital now
Hi Alvind,
I would prefer the plugin method but do you know if I can expect compatibility with generatepress for the next updates/next years?
Thanks in advance!
If a plugin is well-coded and built to work with any WordPress themes then it should always be compatible with GeneratePress.
I hope this helps 🙂
