Where comments block appears
  • I am using GP theme with several types of custom posts. Where is the control for the comments element? By default it shows up after the main content. However, I have created a hook for author info that appears after main content that I want to appear first so I have given it a 1 priority. I have another hook for Related Posts that I want to appear below the Comments so it has a 10 priority. How can I give the Comments a 5 priority?
    Can you give this a shot?
    – Go to your WordPress Dashboard and navigate to Appearance > Elements.
    – Click “Add New” and select “Hook” as your Element Type.
    – In the content area, enter the PHP function to display the comment form:
    <?php
        comment_form();
    – Check Execute PHP.
    – Select the appropriate hook from the list.
    – Adjust the Hook Priority.
    – Go to the “Display Rules” tab and set the location for your comment form.
    Let me know if this helps 🙂
