how I can cut the “white” space between menu, footer and content here https://nikamak.com/reservation/ as i didn’t have that issue on other pages.
Thanks in advance
Nika -
set the themes Content Container to Full Width – see here:
https://docs.generatepress.com/article/content-container/
Aside from the full width it will strip the themes padding, which is where that space is coming from ( Customizer > Layout > Container -> Top Padding ). It also means you don’t need to use the
Full Width
align option on your blocks. -
thanks, it helped on page https://nikamak.com/reservation/ but broke it here https://nikamak.com/blog/
I setted up all padding to 0.
Can you try the Content Container option David suggested above?
Changing the content padding the customizer would change the padding for the entire site which is something that you likely don’t want.
I had and have Full Width with an inner container on the page https://nikamak.com/reservation/ in the settings of the container while editing a page.
and I also have a different view in Customize > Layout > Container:
I have
Container Width where I can set up px, no option “Full Width”
Separating Space where I can set up px
Content Separator where I can set up px
then I have
Content Layout with options to choose from
Container Alignment with options to choose frombut nothing similar to what is described here https://docs.generatepress.com/article/content-container/
Thanks for fast replying
NikaUpD. found it. It was not clear that it has two places to set up “Full Width”.
Hi Nika,
The layout metabox is in the page editor:
https://docs.generatepress.com/article/layout-metabox-overview/#where-is-it -
Yes, I found it. see an update
“UpD. found it. It was not clear that it has two places to set up “Full Width”.Thanks!
The Full-width option in GB containers is just for that container.
The Full-width option in the layout metabox is a GP option, it’s for the entire page.
And there’s another Full-width option in the layout element which is also a GP premium option, that can be bulk applied to pages/posts/archives…
