White space under footer
  • Hi guys,
    I decided to hide the copyright bar on my website as I display it somewhere else. I did that using the following css code I found on the forum:
    footer.site-info {
        display: none;
    While the copyright content is gone now, there’s still white space (a bar) at the bottom of the website. See this image:
    https://imgur.com/a/M1Gs4by
    Strictly speaking, it’s not underneath the footer, but underneath an element I created and that I put below the footer (which contains some text and a link to the privacy policy). I selected “after_footer_widgets” under Hook Name. The background color of the element’s container is not white so I don’t think the element is responsible for this?
    Thank you for your help. Let me know if you need more info.
    Can you link me to your site where I can see this issue?
  • Hi Ying! The site is not live yet so that won’t be possible.
    See this image (footer + element under the footer, both have the same background color):
    https://imgur.com/a/U81H3ls
    The copyright module is not active (& I added the css mentioned in my previous post):
    https://imgur.com/a/kAHGW2K
    The element settings (only some padding left & right, I didn’t touch the rest):
    https://imgur.com/a/bMdLQ5Y
    https://imgur.com/a/rzxmL7j
    https://imgur.com/a/sBG4EOK
    https://imgur.com/a/Ve0pXJ1
    Let me know if you want me to share anything else that can help you identify the issue.
    edit the Element you created, and make sure there is not an empty paragraph block at the bottom of the editor.
    If thats not the issue, can you share a screenshot of the element editor with the list view open.
  • Hi David,
    See the images below:
    https://imgur.com/a/XA4Kj1Q
    https://imgur.com/a/FVbaHOT
    There’s no empty paragraph block?
    Let me know if you need anything else.
  • I can’t tell from the screenshot, I will have to see the live site to know the issue, unfortunately.
  • Ok, no worries, I’ll put the site live next week or next month, will then share the link so you can have a look at it. Many thanks for the quick replies.
  • The Columns Block and the Paragraph blocks have built in Margins , which may be the issue.
    To test that, select the Container Block and give it a large Spacing > Padding Bottom value eg. 200px
    If the gap goes away then you know the above is true.
    For better control here, use a GB Grid Block instead of the core columns block, and GB Headline block instead of the Paragraph block. The GB blocks have full built in spacing controls.
  • That was indeed the issue. Solved now! Thanks a lot for the support.
  • You’re welcome
