Why content postion is changed automatically
  • hi
    how are you
    pls check the screenshot https://prnt.sc/XtEEZ5XFIs_m
    when I changed the heading icon, the coin and the heading text will be changed into centered automatically, not keep the align left like other grid container element
    please help to fix that and where is the problem?
    another one is the background color
    How to let the background color (var(–base-2)) is full from left to right, not the current background section,
    thanks
  • Hi Paulliu,
    Would you be able to disable SG Optimizer temporarily so we can see the raw CSS of your site and assess the issue?
  • HI,
    Already disable SG Optimizer https://prnt.sc/nJRvQLMbD0M-
    select the Headline Block, and go to Layout settings and choose the Align Items > Flex Start ( left hand icon )
  • hi thanks for your reply
    #1 is OK and align left
    but, how about the background color?
    https://prnt.sc/cwS-0P2-JfcP
    pls guide to fix that, thanks
  • It requires another Container Block for the background.
    1. select that Container Block, and remove the background color.
    2. in the Container Block toolbar click the Add to Container.
    3. select the newly added container and add the background to it.
