heathery725
I created an Element to apply to all Pages, as you can see HERE but for some reason it’s flowing through to my Oak Tree page, but not to my Fern Tree page, and I don’t understand why.
Specifically I checked that I don’t have the tag “hub” on this ferns page…but you can see that the Title is repeated in the text section (but it isn’t there in the Oak tree page)…also the CSS a kind support team member gave me that I added in the ‘Additional CSS’ section isn’t flowing through because you can see the Image in my Ferns page doesn’t have the Shadow – can you help me? Thank you!
heathery725
Oops, I think I discovered the answer to half of my question. It looks like I didn’t check the ‘disable content‘ in the ‘disable elements’ on the right side of the specific content page..I checked this and it solved my problem (this was the original as you can see here).
Can you confirm that this is the way I have to go about removing the redundant title since I have it in my Element? And I have to do this in each and every page / post?
If you can help me still with the shadow CSS that would be great! Thank you
The element you’ve created a block element page hero?
https://docs.generatepress.com/article/block-element-page-hero/If so you can use the Disable Title option in the element setting:
https://docs.generatepress.com/article/block-element-page-hero/#settingsPlease open a new topic for the shadow question.
Let me know if this helps 🙂
heathery725
ok thanks Leo!
No problem 🙂
