Why isn’t container clickable with URL?
    I implemented this code taken from another thread to make the container clickable:
    .gb-container.linked-container .gb-inside-container {
    position: relative;
    .gb-container.linked-container a:before {
    content: “”;
    position: absolute;
    top: 0;
    right: 0;
    bottom: 0;
    left: 0;
    z-index: 10;
    However, only the post title is clickable. Not sure why this is
    P.S. I added an example link in Private Info
    It’s clickable with no issue.
    However, you do not need this CSS or container links, the headline block itself is clickable.
  • Hey,
    Sorry for not being clear. I want the whole container to be clickable, not just the headline, which is why I added that code.
  • I want the whole container to be clickable, not just the headline
    It is the case, the container is clickable.
    You can also use a button block instead of the headline block if you want the icon also be clickable.
    I think I’m struggling to explain it properly, I’ve added a red square around the container that I need clickable, is that whole container clickable on your end?
    It is what I am trying to achieve, to make this entire container clickable
  • Oh you mean those containers? But they don’t have the linked-container class, I was referring to the menu items in the slideout navigation.
    https://app.screencast.com/UJZ2XFmF6IcS0
  • Hi Ying,
    I cleared the cache and it does have the linked-container class, but the container is still not clickable :/ please check the new image link
    Try adding this CSS as well:
    .gb-container.linked-container .gb-headline {
      position: initial;
      z-index: 10;
  • Adding that code worked thanks so much!
  • You’re welcome!
