Anonymous
hi
how are youWhy this page hero is not wide-width? https://prnt.sc/BRBYyoZRa4T6
how to fix that and let it to be full width.
thanks
Hi Paulliu,
The inner Container Block of that section has a max-width value of
1200px. Remove that.Then, set the width to
100%. -
Anonymous
hi
how are you
why it is so strange like this https://prnt.sc/UC99QtPvbxXc, others all are good,
pls help to fix that, thanks
Hi Paulliu,
Try setting the Background-size of the Container Block holding the image to
cover.Let us know how it goes.
Anonymous
HI Fernando
i have the same method to set other page hero and others are ok, whty only this one is problem?
pls check other page hero, thanks
The issue is the intrinsic aspect-ratio of the Image you added in relation to the size of the Container Block. The don’t have the same aspect-ratio.
What you can do as an alternative is to increase the value of the top and bottom paddings of the Inner Container to a value probably higher than
160px.
