Widget Footers doesnt work! GP
  • I built a footer with elements and installed it after_footer for all pages (block hook). I also wanted to use the widget footer. But they don’t work. I have specified 3 widget footers, but when I write something in it it is empty. Since I thought it was the Block Hook Footer, I deleted it, but all my widgets still don’t work. There’s a safety lock on it. What did i do wrong? Greetings
  • Sorry! The Mistake is only on the first page. The other pages are ok. What can i do to fix the problem on the startpage?
    Can I see the issue on your site?
  • I discovered what it was about, but unfortunately I couldn’t find the error. When I am on my homepage via the customizer, the following text appears: The theme has seven additional widget areas but this homepage does not display them. You can navigate to other pages on your website while using the customizer to take advantage of the widgets available on those pages! Ok, that’s understandable for everyone. But why can’t I use these footer widgets on the homepage? Funny, that’s exactly where I need you! Many many greetings
    has the Footer been disabled on the home page ?
    Check in the Disable Elements meta box in the page editor:
    https://docs.generatepress.com/article/disable-elements-overview/
    Or check if there is a Layout Element in Appearance > Elements that is disabling them
