Wilder Site – Main Menu Sliding Underline on Hover
  • With the Wilder Site, Main Menu… I am not able to find where or how to change the Main Menu, Sliding Underline on Hover (color, hover effects, etc.). Any help you can provide on this will be greatly appreciated.
    1. Go to appearance > elements, edit the element called Header.
    2. Select the menu item block, click the manage selector button, click &:is(:hover, :focus-within)::after.
    https://app.screencast.com/anTlEcEhPXupb
    3. Then you can change its color in the typography > text color, if you want to change its height, you can find it in the sizing panel.
    Let me know if this is clear!
  • Awesome, thank you!
    I’m now having a hard time finding where to control the Text Color with a Sticky Menu. I found and can change the background color on a Sticky but not the text color? Where might I find this (text, hover, current controls)?
    With the Site Header block selected, create and edit the following selector: &.gb-is-sticky ul > li > a. Change its typography color accordingly.
    Sticky header text color
