WooCommerce Button Layout Issue
  • Hi, wondered if you could offer any help with a WooCommerce button issue on the product archive pages (as per the link attached). So, I’d like to display the 2 buttons ‘View’ and ‘Add’ on the same line next to eachother, with a 47.5% width each. I’ve tried to use display: inline-block with no luck, and cannot use flex as there’s no wrapping container around the buttons. Wondered if you could work your magic! Thanks, David
    you could do something like this:
    #wc-column-container .product {
        flex-direction: row;
        flex-wrap: wrap;
        gap: 1px;
    #wc-column-container * {
        flex-basis: 100%;
    #wc-column-container a:not(:first-of-type) {
        flex: 1 1 calc(50% - 1px);
    Or this:
        flex-wrap: wrap;
        gap: 1px;
        flex-basis: 100%;
    #wc-column-container a:nth-of-type(2) {
        flex: 0 1 0;
    #wc-column-container a:nth-of-type(3) {
        flex: 1 1 0;
    The latter code will allow the but button to take up more space.
  • Great, thanks David…
  • Sorry David, just had to re-open this. Just one small snag – please see the buttons on column 2 “all day decaf” on the screen grab link. The button height seems to be extending to the bottom of the max column height in the row.
    As the topic was marked as resolved, all your site info is gone, can you re-link us to the page in question?
  • Hi Ying, the button issue can be seen on ‘all day decaf’ on the link attached. After implementing option 1 of David’s code, the button height seems to be extending to the bottom of the max column height in the row. Thanks!
  • Try adding this to the CSS:
        align-self: flex-end;
  • Thanks as always David, job done…
  • Glad to be of help
