Woocommerce duplicated cart
  • It looks like the standard WooCommerce mini-cart somehow is duplicated in the page template. The “lower” mini-cart in the site’s code is the one which is loaded last, so it works correctly, as it likely “takes over” the first one.
    See loom for the issue…
    Does the issue still occur if you deactivate all plugins except GP Premium, WooCommerce, and GenerateBlocks? This will help identify if it’s caused by a plugin conflict. I suspect caching might be the culprit, but let’s confirm.
  • All plugins deactivated, included cache.
    Same issue…
    Woocommerce, generateress, generateblocks active
    try disabling the GP Woocommerce module in Appearance > GeneratePress as that adds integrations with Woo which may be conflicting.
  • GP Woocommerce module in Appearance > GeneratePress disabled.
    Same issue..
  • Does the issue appear when switching to a twenty twenty theme?
  • No, on twenty twenty theme it is working
  • Hum….I did some testing, it looks like it only happens when the hook is set to menu_bar_item.
    Can you try using after_navigation hook instead?
  • Then it is working
  • This is a weird issue, I’ll ask the dev team to take a look.
    For now, just use other hooks as a workaround.
  • Also NOT working in “after primary menu”
  • It works for me with after_primary_menu hook, I think it’s because you are using mobile header, so both after_primary_menu and menu_bar_item hooks are added twice, once in the header, and once in the mobile header.
