Woocommerce – Have 2 types of product category menus
  • techbackend04
    I am looking to make two different menus.
    1. In the header which will show menu list based on brands, broader category like men/women/child etc.
    2. In the left side bar, the product category is based on disease.
    Basically I want something similar to the below website.
    https://imgur.com/FkltMZJ
    Wondering is it possible to achieve this, and what plugins or code I have to do.
    Thanks alot.
    1. That should be the primary or secondary menu. What issue are you having there?
    2. I believe one of the blocks from WooCommerce would work in the sidebar widget: https://woocommerce.com/document/woocommerce-product-search/blocks/
  • techbackend04
    Thanks for the response.
    I am just doing e-commerce site for the first time. Will try the above methods.
    Thanks again.
  • Sounds good.
  • techbackend04
    Wondering is it possible to use Elements to create navigation menu in the sidebar?
    Also if I want a third navigation menu below the Secondary Menu in the header section, is it possible to do with Elements? or any other suggestions?
  • You can try using the WP navigation block in the element.
    Let me know how it goes.
  • techbackend04
    Appreciate your guidance, will check that out.
    Thanks so much Ying.
  • You are welcome   🙂
    Let me know how it goes!
