wooCommerce Nav Menu
  • Hi, I wondered if you could help with two wooCommerce nav menu issues:
    (1) I’d like to display an icon next to the ‘account’ link in the top bar menu
    (2) When logged in, woo automatically adds a ‘Log out’ link, but I’d like to show ‘Logged in as [username]’ before the log out link.
    Any help would be appreciated.
    1. You should be able to modify the menu in the topbar at appearance > menus, and paste the SVG icon’s HTML code to the menu label field, then use CSS to adjust its size.
    2. How and where can I see the Logout link?
  • Hi Ying,
    The logout link is appended to the menu by WooCommerce when you’re logged in. Please see:
    https://postimg.cc/QHPcdg5Z
  • It’s doable, but it requires some coding. Try following the below steps:
    1. Go to appearance > menus, edit the navigation that you added to the topbar, add a custom link with URL set to #, navigation label set to [show_username], and CSS classes to logged-in-user-name.
    Here’s a screenshot for your reference: https://app.screencast.com/zqkaEEzKEs01p
    For the CSS classes field, you need to tick it after opening the screen options:https://app.screencast.com/KxdioBbejZrI3
    2. Add this PHP code to create the shortcode and enable the support of shortcode for menu item label field:
    function show_logged_in_username() {
        // Check if the user is logged in
        if (is_user_logged_in()) {
            // Get current user info
            $current_user = wp_get_current_user();
            // Display the user's display name
            return 'Logged in as ' . esc_html($current_user->display_name);
        } else {
            // Show nothing for users who are not logged in
            return '';
    // Register the shortcode
    add_shortcode('show_username', 'show_logged_in_username');
    function enable_shortcodes_in_menu($title, $item, $args, $depth) {
        // Process shortcodes in the menu title
        if (has_shortcode($title, 'show_username')) {
            $title = do_shortcode($title);
        return $title;
    add_filter('nav_menu_item_title', 'enable_shortcodes_in_menu', 10, 4);
    3. Add this CSS to hide the “logged in as” menu item when users are not logged in:
    body:not(.logged-in) .logged-in-user-name {
        display: none;
    Let me know if this works!
  • Great, all working. Thanks as always Ying… David
  • You are welcome   🙂
