Woocommerce Store Notice Covers Header
    I’ve run into an issue during the setup of a Woocommerce store. I enabled the store notice, but the notice covers the header. Is there some CSS that I can add to push the header down only when the notice is displayed?
    Thanks in advance.
    Screenshot
    That’s not possible with CSS unfortunately.
    I think a decent workaround solution would be to create the notice bar manually using a top bar widget:
    https://docs.generatepress.com/article/top-bar-widget-area/
    The only downside is that there wouldn’t be a Dismiss button.
    I hope this helps 🙂
  • Thanks, Leo! That helps. Thought that was where I would be headed. Not really concerned about not being able to dismiss it 🙂
    Thanks again!
  • No problem 🙂
