Working with Font Library Feature (The Fonts Don’t Change)
  • I have watched the GP video to load the local fonts via the font library and made the necessary changes via Customizer but it’s not working.
    I’m sure I am missing something but couldn’t figure out what. I read the forums and then disabled the cache plugins. No change.
    Please let me know if you need something further to investigate.
    Best,
    Can you go to settings > general, check if you are using http in WP address and Site address, if so, change it to https, and save the change.
    Then go to the font library, disable the font, save, then enable the font again to generate new paths for font files, so they can update the path to use https instead of http.
    Let me know if this helps!
  • It worked perfect! Thank you!!
  • Glad to hear that 🙂
