Wp Events Manager QueryLoop
  • chaselifetech
    I use generatepress premium and generate blocks pro. On a website dawngreenyoga.com . On the home screen towards the bottom it displays events using WP Events Manager. I currently use your old plugin WP Show Posts which has not been updated for 2 years now.
    I would like to instead use the QueryLoop in generate blocks. But I’m unable to find the data to link to it the query loop.
    Please help
    Many thanks
  • Hi David,
    What does this mean? I don’t quite understand your issue.
    Are you having difficulties adding a query block? Do you mean you don’t know what query parameters are added to the WPSP?
  • chaselifetech
    I don’t know the parameters to add to the meta from the WP events manager plugin in the generate blocks query block. Is there a way of finding this out? Not having much luck from the events manager plugin
  • Looks like the post Welcome back in the My Latest Yoga & Wellness Blogs section is just a regular post. You should be able to use GB’s query block to pull posts. I don’t think you need to add any parameters; the default settings should do.
    Let me know if I miss anything!
  • chaselifetech
    It’s the events which I’m referring too which are above.
    Many thanks
  • The WPSP is showing a regular post:
    https://app.screencast.com/VwbnLNTLWode7
    So this is not the post you want to show? You want to show events?
    If so, add a query block, and set the post type to events, instead of posts.
    Let me know if this helps!
