WP Rocket / Imagify breaking query loop images
  • Hello, I’m having an issue with image sizing in a query loop when viewing the mobile site. Specifically, I have set the images in this query to exact dimensions of 100×100 and object-fit to cover.
    For some reason after installing wp rocket with imagify, now I see the images of all query loops without the standard formating.
    You can see it here: hiperfutbol.com
    Based on a similar scenario in another topic, the OP mentioned that Imagify was causing the issue. To confirm, does the image display properly in the intended layout when Imagify is deactivated?
