Search for: xml feed integration gpetar June 27, 2026 at 4:35 pm Hello, is there a way to show the content of integrated XML or JSON files in the blog post? I will send the feed file content in the private section. Any kind of solution is welcome, directly in the theme or with an additional plugin Thanks Alvind June 28, 2026 at 8:32 pm Hi there, GeneratePress does not include a native feature for handling this. You may want to try one of these plugins instead: https://wordpress.org/plugins/json-content-importer/ https://wordpress.org/plugins/wp-all-import/ Viewing 2 posts - 1 through 2 (of 2 total) You must be logged in to reply to this topic.
