Yoast Breadcrumbs not being detected by Google
    I have being using Generate Press and Yoast for months and without issues. Since some days I noticed Google stopped detecting my Breadcrumbs. I can see them in my pages, I can see it active in Yoast and looks like I see them in my Generate Press (picture in attach).
    I did some troubleshooting in Yoast and looks like all is fine 8n their end so I am wondering if the issue is in GP …
    Could you try to give me some help ?
    What specific test are you using to detect if the Breadcrumbs is available?
    This shouldn’t be a GP issue since GP only hooks the Breadcrumb – nothing more. If it shows in the Frontend, technically, it should be detected.
    I’m thinking that your testing tool is seeing a cached version of your site or some other issue.
  • Hi Fernando
    I using Google Rich Result Test (https://search.google.com/test/rich-results) and I disabled my Cache Plugin already.
    When I open the source code I see two other Rich Results (Article and FAQ) but not the Breadcrumbs.
    Let me double-check something with you.
    When I go to Appearance, Elements, and Click in my “Breadcrumbs” I see
    “[/] Shortcode”
    [wpseo_breadcrumb]
    and in Display Rules, “Post” and “All Posts”
    in Elements I see “Hook” and “before_entry_title” and Priority 10.
    Is the Priority Correct ? Are these other fields correct ?
    Just making sure it is correct inside Generate Press
  • I found the issue. It was in another plugin.
    Thank you !
  • I see. Glad you resolved it!
