“You might also like” products in cart on mobile are big
    For some products I have added connected products which show up in cart after you add them.
    I’m talking about this: https://prnt.sc/oMlVMqjbH-SQ
    The problem is that when you’re in the cart on your phone, these products take up the whole screen: https://prnt.sc/GgwNY7De43Gu
    How can these recommended products be made smaller in the cart for mobile? On desktop their size is okay.
    Sending you a link in the private area to test.
    the theme has no control over the woo cart block, so you would need to treat it with some CSS :
    @media(max-width: 768px) {
        .wc-block-cart__main,
        .wc-block-cart__sidebar {
            padding: 20px !important;
        .wp-block-woocommerce-cart-cross-sells-block h2 {
            font-size: 1.5rem !important;
            margin-block: 1rem;
        .wp-block-woocommerce-cart-cross-sells-block > div {
            display: grid;
            gap: 1rem;
            grid-template-columns: repeat(2, 1fr);
    This will add some spacing around the cart, reduce cross sell heading sizes and make the cross sell products a 2 column grid.
  • Hello David,
    I added the CSS through the Customizer but unfortunately nothing happened :/
  • I don’t see the CSS in your customizer, do you have cache plugin? Have you cleared cache after the changes made?
  • Now it works! Thank you so much! I thought the cart is non cacheable.
    I wanted to ask how can the cross sale products in the cart have a green buy button? Now it’s grey and I don’t know how to change it.
  • Can you share the link to the product again ?
  • Yes, added it in the private area
  • Can you set the color for the button in the cross-sell product block?
    if not, then try this CSS:
    .cross-sells-product .wp-block-button.wc-block-components-product-button.wp-block-cart-cross-sells-product__product-add-to-cart a {
        background-color:green;
  • Thank you so much! The block had no color option but the CSS worked.
  • You are welcome   🙂
