Luca Cogo
I am trying to create a zoom effect on an image or background image, with the effect remaining within the dimensions and border of the container. I would like the zoom to only affect the image without enlarging the entire container.
Something like on at the bottom of your theme “Wilder” home page.
How can I do this?
Thanks a lot! -
George
Hi Luca. This would work easier with an image.
1. Set the image’s parent container to OVERFLOW-X and OVERFLOW-Y to
hiddenfrom the Position settings on the right.
2. Select the image and add a TRANSITION from the Effects panel.
3. With the image selected, select the Hover selector and add a Transform effect with a TRANSFORM TYPE of
Scaleand a SCALE value of 1.1 from the Effects panel.
Let me know how it goes!
Luca Cogo
Hi George, it works!
There is still one problem: the corners of the image border are rounded, but when hovering, they return to right angles. I added the border radius value to the hover section as well, but that didn’t solve the problem… -
George
Hi again.
Please, remove the border radius from the image, also from the hover selector. Apply the border radius to the image container instead.
Luca Cogo
Perfect!
Thanks a lot -
George
No problem!
Luca Cogo
@George Is it possible to create a hover effect with a background image?
George
Yes, but you need GenerateBlocks Pro for this, otherwise, it can be achieved with some custom CSS. Let me know your preference.
Luca Cogo
Hi George,
if it’s not too hard (I’m not a professional website builder), let’s try with CSS 🙂 -
George
No problem, just follow my lead!
Create a container and set POSITION to
Relative. Also, set OVERFLOW-X and OVERFLOW-Y tohidden.
Set some paddings or a fixed height.
Set a custom class to this container, eg:
hover-scale-bg
Insert this CSS:
.hover-scale-bg::before { content: ''; position: absolute; top: 0; left: 0; width: 100%; height: 100%; background-image: url('your-image.jpg'); background-size: cover; background-position: center; transition: transform 0.4s ease; z-index: -1; } .hover-scale-bg:hover::before { transform: scale(1.1); }Insert it either in the Customizer or inside you child theme.
https://docs.generatepress.com/article/adding-css/Let me know how it goes!
Luca Cogo
I do, but it doesn’t work… I think I do all as you said, can you check in private link. It is at the page bottom 🙂
George
Please, do not upload a background image on the container, you need to remove that.
Then, in your CSS, you need to add the URL of your image:
.hover-scale-bg::before { content: ''; position: absolute; top: 0; left: 0; width: 100%; height: 100%; background-image: url('https://www.staging2.baitarondanino.it/wp-content/uploads/2021/11/Esterni-Gallery-6.jpg'); background-size: cover; background-position: center; transition: transform 0.4s ease; z-index: -1; } .hover-scale-bg:hover::before { transform: scale(1.1); }As you can see the actual image is being added in CSS through a
::beforepseudo-element. -
Luca Cogo
Ah ok, thanks.
I thought I could achieve the effect with a different image for each container, but instead with this method I use a single image for all the different containers… -
George
You can change the image URL in the CSS provided to have a different image, it doesn’t have to be the same. You could add another class next to the
hover-scale-bgone, let’s sayimage-2orimage-3.Then have this:
.hover-scale-bg::before { content: ''; position: absolute; top: 0; left: 0; width: 100%; height: 100%; background-size: cover; background-position: center; transition: transform 0.4s ease; z-index: -1; } .hover-scale-bg:hover::before { transform: scale(1.1); } .hover-scale-bg.image-2::before { background-image: url('https://www.staging2.baitarondanino.it/wp-content/uploads/2021/11/another-image.jpg'); } .hover-scale-bg.image-3::before { background-image: url('https://www.staging2.baitarondanino.it/wp-content/uploads/2021/11/yet-another-image.jpg'); }Let me know if you want further explanation.
Luca Cogo
I try, only first code too, but doesn’t work…
I don’t understand where is the problem -
George
Ok, please remove
z-index: -1;from this code:
