jmurphree
forum.worldhealth.net – we figured out how to develop our animated logo so that it doesn’t take up a lot of space, but now we’d like to move it from the right sidebar to replace the site logo. Any way we can do this with elements?
https://forum.worldhealth.net/news/vigorous-exercise-may-preserve-cognition/
Try using this filter, and replace
images HTML here
with the images.add_filter( 'generate_logo_output', 'tu_logo_class', 10, 3 ); function tu_logo_class( $output, $logo_url, $html_attr ) { printf( '<div class="site-logo"> <a href="%1$s" title="%2$s" rel="home"> <figure class="aligncenter size-full kb-image-is-ratio-size"><div class="kb-is-ratio-image kb-image-ratio-square">images HTML here</div></figure> </a> </div>', esc_url( apply_filters( 'generate_logo_href' , home_url( '/' ) ) ), esc_attr( apply_filters( 'generate_logo_title', get_bloginfo( 'name', 'display' ) ) ), $html_attr ); }
jmurphree
Hey, thank you for the prompt reply – this is not exactly what I was looking for. We want to put a custom widget in place of the site-logo. The animated logo uses two images, one for an image widget which css animation is applied so it can rotate, then a custom background image is defined in CSS to remain stationary. That’s the globe.
Sorry, I didn’t get an email showing your reply or I looked over it. Will check more frequently since you are very responsive!
Would you be able to rebuild the animating logo using a block element? If so, we can try to determine the best method, such as using a hook or something else to use it as a site logo.
jmurphree
Sounds like a plan, let me do that and I’ll check back in – most likely later today. Please keep this topic open until we can resolve. We love GeneratePress and use it on ALL websites
No problem, let us know how you get on
jmurphree
I got it, thank you for the help – I just had to remake the whole header as an element and it came out looking great! https://forum.worldhealth.net
The best I can tell, this animated logo does not impact loading times at all – it’s literally just a png with css animation and another background png. We’ll see…
Looks great indeed! I’m glad you managed to sort it out 😀
