Stefanie
Hi team,
I have created a page hero with two different background images.
I would like the svg to sit as a small icon in the bottom right corner of the page hero. But the problem is that I can’t specify a size for the icon.
I can only specify a WP size there via a dropdown: https://prnt.sc/9iSo-HVBqLFk
But I would like to set the svg to 150 or 200px. How do I do that?
Hi Stefanie,
You have this CSS:
.bg-gradient-hero { background-blend-mode: normal,,; //the two , should be removed background: url(https://demo.insight-inside.de/wp-content/uploads/2024/06/noun-nature-1.svg) bottom -20px right 4px / contain no-repeat, linear-gradient(135deg, rgba(97, 199, 163, 0.9) 0%, rgba(42, 106, 45, 0.9) 52%, rgba(5, 27, 6, 0.9) 100%), url(https://demo.insight-inside.de/wp-content/uploads/2024/06/goutham-krishna-h5wvMCdOV3w-unsplash.webp) 52% 66% / cover no-repeat; }
You’ve set the image size to
contain
, just change it to150px
..bg-gradient-hero { background-blend-mode: normal; background: url(https://demo.insight-inside.de/wp-content/uploads/2024/06/noun-nature-1.svg) bottom -20px right 4px / 150px no-repeat, linear-gradient(135deg, rgba(97, 199, 163, 0.9) 0%, rgba(42, 106, 45, 0.9) 52%, rgba(5, 27, 6, 0.9) 100%), url(https://demo.insight-inside.de/wp-content/uploads/2024/06/goutham-krishna-h5wvMCdOV3w-unsplash.webp) 52% 66% / cover no-repeat; }
Stefanie
Hi Ying
Thank you for your quick reply.
The problem is that I can’t set it there. It’s also a dropdown, you can’t enter a free value there: https://prnt.sc/oe6ZHof9GBNG
Stefanie
I have just discovered that you can enter a free value there if you know where 🙂
Problem solved.
Thank you 🙂 -
