Is it possible to create an accordeon with the opacity effect shown in the image?
i would probably NOT use the Accordion for that, as it would be a bit hacky.
Instead i would use other blocks and some JS.
Set the Layout as such:
Container Block #1 ---- Your other content goes here ---- Container Block #2 ---- ---- GB Button
Container Block #1 give it an Advanced > Additional CSS Class of:
reveal-content
Container Block #2 give it an Advanced > Additional CSS Class of:reveal-button
GB Button give it a class ofreveal
Add this Javascript to the site:
<script> document.addEventListener("DOMContentLoaded", function() { var revealLinks = document.querySelectorAll('.reveal'); revealLinks.forEach(function(link) { link.addEventListener('click', function(e) { e.preventDefault(); var revealContent = this.closest('.reveal-content'); revealContent.classList.toggle('show'); }); }); }); </script>
This will toggle the
show
class on the reveal-content container when the button is pressed.Now add this CSS:
.reveal-content { position: relative; overflow: hidden; padding-bottom: 80px; /* space for the button */ } .reveal-content:not(.show) { max-height: 400px; } .reveal-button { position: absolute; inset: 0; top: unset; }
Some of these styles can be applied in the block styles if you want but the main work is the CSS that sets the
max-height
property when the SHOW class is NOT present.Then its case of stying that
reveal-button
container eg. add a Gradient background for the fade and center the button. -
Works like charm but not on mobile 😀
That CSS its not wrapped inside a desktop only media query ?
If it isn’t can i see the issue on the site -
Nevermind, works now. I had to clear the cache.
Glad to hear that!
