ACF Link Type Not Show In Result
    1. I set a field in ACF with Field Type is Link.
    2. The field name is “whatsapp_button” and return value is Link URL
    3. And then in the post edit, i try make a text, and set content source to post meta, and post meta field to whatsapp_button.
    4. In etra field under my edit post, i insert the URL and link text.
    5. I update it but nothing show in result.
    Please help
  • Hi there
    in step 3
    Don’t use the Content Source, set the Link Source instead to add your whatsapp_button Post Meta value.
  • I already try used the Link Source, but when i click the button, it’s not leads to URL link that i input in ACF Field in post edit. It leads me to current post link and at the end of the link there is /Array (https://abcd.com/currentpost/Array)
  • Temporarily disable the Dynamic Data
    Select the Button block and inits URL field add a #
    Then add the Dynamic Data as a Link Source.
