Hi Team,
How can I add image alt text in the author box?
https://www.cheapmedicineshop.com/blog/eyecare/eye-strain-remedies/ -
Hi Ansh,
If you have GB Pro, you can add an aria-label custom attribute through the Advanced options of the Block Settings: https://docs.generateblocks.com/article/custom-attributes/
You can also do it via custom PHP code with a filter like the WordPress filter
render_block
if you don’t have GB Pro. -
Thanks, Fernando,
We are not using GB pro, we are only using GP premium.
Can you please write PHP code for me?
Best Regards
What I can do is provide a sample that can help you achieve what our GB Pro custom attribute feature does. See this example: https://generate.support/topic/discernible-link-name-for-dynamic-images/#post-56047:~:text=Hi%20Slaven%2C-,Can%20you%20try%20this%3F%3A,-1.%20Can%20you
Hope that helps!
Thanks for your reply,
Can you please provide me the code with the required changes?
I don’t have knowledge of wp functions and PHP.Best Regards
try adding this PHP Snippet to your site:
add_filter('get_avatar', function($text){ $alt = get_the_author_meta( 'display_name' ); $text = str_replace('alt=\'\'', 'alt=\'Image of '.$alt.'\' title=\'Avatar for '.$alt.'\'',$text); return $text; });
Thanks, David
Same issues after adding this code.
Can you please check accessibility on this page speed report?
https://pagespeed.web.dev/analysis/https-www-goodrxmedicine-com-blog-sexual-wellness-cialis-side-effects/ka0kbnddil?form_factor=mobileRegards
May I know how you added the snippet?
In Function.php of Generatepress child theme.
You are using an image optimize plugin, which changes the HTML of the image.
I wonder if that’s the reason that the snippet doesn’t work, can you try disabling the
tag in the plugin to test? -
yes,
I am using Imagify.
I just turned it off, and the picture tag is removed now.
But the same issues.
https://pagespeed.web.dev/analysis/https-www-goodrxmedicine-com-blog-sexual-wellness-cialis-side-effects/74mbtwtjjj?form_factor=mobileRegards
The
alt
is still not being added, I can not log into your site to check the backend, the login link returns 404.Can you check?
It maybe remove /blog between domain name and wp-admin.
Can you please add this manually in your addressbar?Regards
The alt issue is fixed now.
Can you please check how we can fix Links that do not have a discernible name issue with the same block?Regards
The issue with the discernible name should be resolved when the image has an alt tag, as it will use the alternate text as the discernible name.
Hi
It shows alt tag as empty tag.
Abd all images in my media library has an alt text.
Can you please check?
