Womari21
Hello support team,
I am using GP or GB default paragraph for my article, and now I want to add bullet lists or numbered list, after selecting multiple paragraphs for apply these – there are no options for these lists, but in the default WordPress Gutenberg it has an option for apply these.
Is there any solution?
Thank you for the attention!
Best regards
Walikhan -
you cannot convert a GenerateBlocks Headline block to a list.
you would need to first convert them to a core Text block, and then convert them to a list -
Womari21
Hi David,
Thank you for the detail, the default Text Block from WordPress has a massive limitation regarding spacing and other options, due to these restrictions I am not able to achieve my goal.
Is there any alternative solution by installing 3rd party plugins?Thank you for your attention.
Best Regards
Walikhan -
If you have to use list element, then look for a plugin that offers list block.
Or if you just want it to visually look like a list, you can add a dot svg icon to the headlines of GB.
