Hi there
I’m trying to add a line under the headline that will look like this: https://ibb.co/vv5Wd0v -
Select the Headline Block and:
1. in Layout set the Display to Inline-block
2. in Effects -> Add a Box Shadow effect.
2.1 set it to Inset and add a solid Color.
2.2 setHORIZONTAL OFFSET
,BLUR
andSPREAD
to0
2.1 set theVERTICAL OFFSET
to a negative value to pull the color up behind. -
Thanks David, is there a way to do this without the effects?
Yes, you can add the headline block into a container and set the container to
display:inline-flex
;Then set a background gradient for the container block:
https://www.screencast.com/t/CVjiZbWGf -
Nice! thank you 🙂
No problem 🙂
