thuan7383
Can i Adding Post Headline (H2) in Sticky Navigation?
Hi Thuan,
You can use a Block Element – Hook type in Appearance Elements:
https://docs.generatepress.com/article/block-element-hook/
In the Hook select box, you can choose:
menu_bar_items
And set the Display Rules > Location to Entire Site or the specific places you want to use.Whatever you add to the block element editor will now be displayed after the Menu items, on Desktop, Mobile, and Sticky Navigation.
If needed, we can use some CSS to remove the item where it is not required.
thuan7383
Thank you Fernandoazarcon2.
What do I need to add the block element editor to automatically select H2 tags in posts to display on Sticky Navigation? -
You can use a GB Headline Block’s Dynamic options. Reference: https://docs.generateblocks.com/article/dynamic-data-options-overview/
