aleksanderk
What is the most straightforward way to add a “Search” button/option to the header? Is a separate plugin required for GP?
You can enable the navigation search modal at customizer > layout > primary navigation.
aleksanderk
Hi Ying,
That seems to affect an already existing element/header/layout where it simply shifts it from top-bottom-left-right. Right now, there’s no search access at all in my header. Here’s default search setting from OWP https://imgur.com/a/w7y2Vfn
The image link doesn’t work.
Can I see your site?
aleksanderk
Hi Ying,
Added temp link to private
can you follow Yings instruction ie.
So we can then see the issue ?
aleksanderk
Hi David,
Upon a second look, it was my bad, my sincere apologies, solved.
Glad to hear that 🙂
