greggzambrovitz
Hi – couldn’t find answer in forum – I use the following “additional css” for image padding which works fine on desktop but not on mobile:
figure.wp-block-image,
.gb-grid-wrapper figure.wp-block-image {
margin-bottom: 2em;
margin-top: 2em;
}So I tried adding this “additional css” for mobile but does not work:
@media (max-width: 768px) {
margin-bottom: 2em !important;
margin-top: 2em !important;
}I seem to remember that “additional css” gets stripped on mobile. For example, if you set font size in “additional css” area it won’t work on mobile – so you have to edit it in the typography settings area for it to work on mobile.
But, I don’t know how to work around the padding issue for mobile.
Thanks in advance.
Hi Greg,
I can’t seem to see your Additional CSS being loaded. Do you have a plugin that’s causing this?
Can you try disabling plugins like Autoptimize temporarily first, and we’ll try to recheck?
greggzambrovitz
I disabled Autoptimize – thx
There’s a syntax error in your Additional CSS code.
There’s a missing closing bracket
}here:@media(min-width: 769px) { .nav-align-center .inside-navigation { max-width: 1200px; margin: auto; } .slideout-navigation.main-navigation .main-nav ul li a { text-align: center !important; } span.author.vcard a { pointer-events: none; color: #000000; } .main-title a:hover { color: #174bd2; } .main-navigation { box-shadow: 0 2px 2px -2px rgb(0 0 0 / 20%); } .entry-title a:hover { color: #174bd2; } figure.wp-block-image, .gb-grid-wrapper figure.wp-block-image { margin-bottom: 2em; margin-top: 2em; }You need to add one somewhere there. The missing closing bracket is causing issues.
greggzambrovitz
ah man, sorry about that.
you are right – the missing closing bracket for unrelated css – I did check the css before I opened support – but guess I missed that.
this problem is now fixed – sorry you had to edit my crap css work – lol.
but, that’s why I tell everyone to use GP – great theme – better support.
take the rest of the day off and do some shots….thanks a bunch.
You’re welcome, Greg! Have a great day as well!
