usethebitcoin
Hi
I wanted to add a subscribe button on the navibation, currenly I am using the menua designed in Customized area, not a block element. Is this possible? Thank you so much.
Yes, you can add a button to a block element – hook, set the hook name to
menu_bar_items
, set the location to entire site or depends on where you want to show it.Let me know if this helps!
usethebitcoin
Thanks for this,
It is working but how will I fix this one.
https://i.postimg.cc/02JYSqpH/Screenshot-9.jpg -
usethebitcoin
I reduced the text size of the navigation menu, and it looks fine. But if you have a more creative suggestion for me, I appreciate it.
You can also try making the header full width.
Go to customizer > layout > header, set Inner Header Width to Full.
usethebitcoin
Thank you Ying that was a big help.
usethebitcoin
Another one Ying,
I wanted to fix the positions of the headers on mobile view. There are limited options in Customise.
https://i.postimg.cc/DytwFQ86/Screenshot-11.jpgAlso for the mobile menu, Slide instead of Overlay. Is there any solution to create a much better header menu design for mobile menu?
https://i.postimg.cc/DytwFQ86/Screenshot-11.jpg -
Try to enable the mobile header at customizer > layout > header.
And please open a new topic for the new question and attach your site link again as this one has been resolved, and the site info has been erased for privacy purposes.
