Joaquim Galante
Hi, i have this messages on wp widgets can you help me to solve that?
The “media_image” block is affected by errors and may not work correctly. See developer tools for more details
The “Search” block is affected by errors and may not work correctly. See developer tools for more details
The “categories” block is affected by errors and may not work correctly. See developer tools for more details
The “text” block is affected by errors and may not work correctly. See developer tools for more details
The “custom_html” block is affected by errors and may not work correctly. See developer tools for more details
The “Isi_widget” block is affected by errors and may not work correctly. See developer tools for more details
The “archives” block is affected by errors and may not work correctly. See developer tools for more details
Thanks a lot
J. Galante
I don’t believe this is a theme issue.
Can you try #1 here to debug first?
https://docs.generatepress.com/article/debugging-tips/If that doesn’t help then try #4 in the same article.
In case this helps. I had the same issue as Joaquim and I deleted all Inactive Widgets (they were very old content) and this solved the problem.
Thanks for sharing your solution!
