dpav111
Good Day,
I am currently using the advanced setting on “Backgrounds” using wider images for desktop and longer images for mobile. Is there an alternative to the “background” feature to achieve this same result? For example having a completely different image or size appear on desktop from what appears on mobile without using the advanced “background” feature? My understanding is that images do not get indexed when using this feature.
I understand images (png, jpg) get resized from desktop to mobile but interested if there is an option to change image or ratio and not use “background”.
I’ve added a url below as an example.
Thank you for your insight and assistance!
Sincerely,
Darin -
No, images are HTML, while background image is CSS. You can not change HTML easily.
But you should be able to use CSS to change its ratio for different screen widths.
dpav111
Thank you Ying. I appreciate your explanation.
One last question. Is there a feature to use a different (html) image for Mobile instead of resizing the Desktop image for mobile using CSS?
Thanks again!
Darin
No, there isn’t a built-in solution for this, as I said changing HTML is not that easy.
You might want to use 2 image blocks, one for mobile and one for desktop, and hide one of them using the hid on desktop/hide-on-mobile option of GB blocks. https://docs.generateblocks.com/article/advanced-options-overview/#hide-on-options-pro-feature
dpav111
Thank you for the information Ying! I will give your recommendation a try.
Much appreciated.
Have a great day! 🙂Darin
