conne9090
Hallo, ich würde gerne Iframes von Site Stripe amazon in meine Homepage einbinden, mein WordPress zeigt aber nicht an wenn ich den ifram einbinde. Woran kann das liegen ?
Grüße Conrad
how are you adding them ? As i do not see any code for the iframe ?
conne9090
You can only see it if you are logged in.
Is it possible that I have to activate something, is WordPress blocking something?
https://legal-drei-pflanzen.de/wp-content/uploads/2023/05/iframe.jpg
Usually, iframe would work right away, there’s no specific setting required.
I would recommend reaching out to the code provider.
Meanwhile, try disabling all plugins except GP Premium to eliminate plugin conflicts.
conne9090
So I’ve tried a few things now, it’s funny that the pictures are displayed on my mobile phone. Plugins all disabled, to no avail.
Anything inside the
<iframe>
tag is locked to its origin sever.
Which means the only code that can affect its conent must come from that server.
Which in this case its Amazons ad servers.Theres nothing the theme or any other 3rd party code can do to change that.
The only other issue is the browser doesn’t like the code, but this would return an error in the browser developers tools console tab.
Its not uncommon for amazon / affiliate codes to take their time before they display correctly. But if they do not you will need to address issue with amazon support.
conne9090
ok i did that, let’s see what comes out.
Thanks very much
You’re welcome
